Creating a New Safety Document from the Control Tool
To create a new Stand Alone Safety Document from the Control Tool, do the following:
1. Make sure the Viewer is in Real Time mode. The safety document creation options are only available in Real‑Time mode.
2. Open the Control Tool for the device to be associated with a new safety document.
3. Click the Safety Documents... button and then select the option to create the new safety document type:
• Create HOLD Document
• Create HOT Document
• Create Clearance Document
• Create Information Document
• Create Warning Document
• Create Delegated Control Document
A new safety document will be created with the Tag Points list automatically populated with the originating device's id and full set of phases. The safety document's Device field will be automatically populated with the source device used to bring up the Control Tool.
Using Stand Alone Safety Documents
