Limits
• Limit Type is either Normal, Emergency (Long Term), or Emergency (Short Term).
• Season allows you to select the simulation season.
• Summer
• Fall
• Winter
• Spring
Note: The season drop‑down list will only be displayed if seasonal limits have been configured. If a project is using temperature based device limits, this option will not be available.
• High Voltage Limit is the high voltage to use for reporting limit violations.
• Low Voltage Limit is the low voltage limit to use.
To request a Power Flow solution using the entered values , click OK. When the system is finished calculating the results, the Power Flow Study Mode Load Scenario window will close and the results will be displayed in the Power Flow Results tab on the balloon details dialog box.
Note: Values are not saved when you apply them. The next time you open this dialog box, the last saved values (rather than the last applied values) will be displayed. If no values were previously saved, real-time values will be used.
• To reset to previous values, click Reset. If you want to request a solution for the default values, click OK.
• To close the dialog box without any action, click Cancel.
