Menu Option | Description | Toolbar Icon |
Print... | Opens the Print dialog box, which allows to print the report. | |
Exit | Closes the Conductor Impedance Mismatch Tool window. | -- |
Run Analysis... | Opens the Feeder Data Analysis dialog box, which allows you to input the analysis runtime in minutes. | |
Stop Analysis... | Stops the feeder data analysis if it has not already finished and displays the report in the table. | |
View... | Displays the selected conductor in the viewer. | |
Copy | Copies selected rows. | |
Purge Analysis Results... | Opens a confirmation dialog box that allows you to purge old analysis results. |
Conductor Impedance Mismatch Analysis Tool Help | Opens the online help system to the Conductor Impedance Mismatch Tool help content. | -- |
