Conductor Impedance Mismatch Tool Report
The conductor impedance mismatch tool report has following columns:
1. Feeder: Name of the feeder where the mismatched conductor is found.
2. Phase: Phase of the feeder where the mismatched conductor is found.
3. Conductor: Name of the mismatched conductor.
4. Conductor Catalog: Name of the catalog of the mismatched conductor.
5. Connected Conductor: Name of the conductor against which mismatched conductor is compared.
6. Connected Conductor Catalog: Name of the catalog of the conductor against which mismatched conductor is compared.
7. Percent Difference: Percentage impedance difference between the mismatched conductor and the connected conductor.
8. Error Type: Name of the possible error type.
Note: If needed, you can select multiple rows within the report and copy and paste to an external application.
The status bar indicates the number of rows in the report and includes an indicator that spins when calculations are in progress.
