Button | Description |
Displays the dialog box that allows you to sort the results table as desired. | |
Displays the dialog box that allows you to filter the table as desired. | |
Reloads the entire table displaying any newly created Feeder Contingency Analysis plans. | |
Displays the Feeder Contingency Analysis plan details for the selected row. This will show pertinent information such as steps, power flow results, affected feeders, and overload information | |
Displays the main feeder being affected by the Suggested Switching Steps. | |
Resolves the rows that are currently selected in the table. This would be used for situations where the as‑built topology changed for a feeder that is being analyzed, but the quarterly resolve has not been conducted by the system administrator. | |
Opens the Feeder Contingency Analysis dialog box, which allows the user input the analysis runtime in minutes. | |
Stops the feeder contingency analysis if it has not already finished. | |
Copies selected rows. | |
Opens a confirmation dialog box that allows you to purge old analysis results. |
