Configuration (Administration Users)
To enable this, the following SRS rules need to be configured using Configuration Assistant.
Rule: Capacitor Operations Count Penalty Threshold
• Rule_value_1: Class name of the capacitors
• Rule_value_2: Threshold count of close operations to penalize a capacitor
Rule: Capacitor Operations History Period
• Rule_value_2: Number of days to consider back in time to count the close operations. By default, it is one day (last calendar day).
Rule: Use Rolling Period Capacitor Operations Count to Penalize
• Rule_value_1: yes or no. By default, it is no (use the count of operations in the last calendar day). If it is set to yes, then the operations in the last 24 hours are used to determine the count and penalize the capacitors.
Rule: Capacitor Operations Penalty Weight
• rule_value_integer_1: Enable: 0 - No, 1 - Yes. Default: 0.
• rule_value_2: Weight.
Note: Currently weight is not in use. Optimization penalizes a capacitors whose operations exceed a threshold by excluding it, if rule_value_integer_1 is set to 1. If there are still violations in the plan, it checks if the capacitor can help relieve them. If it helps, then it will come up with a plan that includes the capacitor.
