Summary Information
• Min Volt (%): The minimum service voltage in the optimization area.
• Max Volt (%): The maximum service voltage in the optimization area.
• Loading: The total loading in the affected area showing both real and reactive power.
• % Reduction (kW): This value will be displayed when Conservation Voltage Reduction, Loss Minimization, or Relieve Overloads objectives are selected. For Conservation Voltage Reduction or Relieve Overloads, it will display the percent change in reduced demand. For Loss Minimization, it will display the percent change in reduced losses.
• DER Gen: The total DER output in the optimization area for real and reactive power.
• PF Change: This will only display for the Power Factor Correction objective and will display the change in power factor.
• % Voltage Change: This value will be displayed for the Maximize Voltage objective. It will display the percent change in maximum voltage by executing the optimization plan.
• % Increase (kVAr): This value will be displayed for the Maximize VAr objective. It will display the percent change in reactive VAr support by executing the optimization plan.
• Losses (kW): The total losses in the optimization area.
• Power Factor: The overall power factor for the optimization area.
Note: Power factor will be negative for leading and positive for lagging.
• Violations: The total number of violations in the optimization area.
• Warnings: The total number of warnings in the optimization area.
