Help Menu
Menu Option
Description
Toolbar Icon
Load Shed and Restoration Help
Opens the online help system to the Load Shed and Restoration Help help content.
Selected Load Pane
The Selected Load pane contains values for the total Configured Load, net load (Net PF Load), and DER output calculated from power flow (PF Gen) for the load groups selected in the Load Groups pane.
Find Groups Pane
You can find load groups by specifying search criteria.
• SCADA Only: Select this check box to search only SCADA load groups. Otherwise, both SCADA and manual load groups will be searched.
• Allow shedding of critical customers: Select this check box to allow shedding of critical customers.
• Feeders in nominal state only: Select this check box to find groups with feeders in nominal state only.
• Net load to shed (MW): Specify amount of net load in MW to shed. Search button is enabled when the amount is specified.
• DER Output less than (MW): Specify DER output in MW. This field is displayed only when power flow is licensed.
When you click Search, the load groups matching the search criteria will be selected in the load groups table.
Load Groups Pane
The Load Groups pane displays the load groups configured in the zones you have subscribed to.
