Menu Option | Description | Toolbar Icon |
Earliest Alarms | The Earliest Alarms list shows closest in time problems for each feeder. The list is sorted by the Date/Time column showing earlier problems first. If a feeder does not have any violations or warnings in the next 6 days, it will not be presented in the list. | See note. |
Worst Case | The Worst Case list shows worst Feeder Condition for each feeder in the next 6 days. The list is sorted by the score showing worse problems first. | See note. |
Present Loads | The Present Loads list shows the current loads, sorted by score. | See note. |
