The Feeder Load Summary window status bar displays the user type: Administration, Full Operations plus Switching, or View Only.
The Administration user's status bar provides access to the resolve and re-forecast function.
The resolve and re-forecast () starts a new Feeder Load Management calculation. If a calculation is already in progress, the system will return a message that a forecast is in progress and that changes will be reflected in the next solution, which will begin immediately after the in-progress calculation is completed.
Understanding the Feeder Load Summary Data Table
The Feeder Load Summary window displays a table shows a list of feeders and their conditions and attributes. By default, the Earliest Alarms view is displayed. Other available views are Worst Case Loads and Present Loads. To switch between views, select the desired option from the View menu or from the drop-down list in the toolbar.
