Limits Pane
• Limit Type: The Limit Type is either Normal, Emergency (Long Term), or Emergency (Short Term).
• Season: Indicates the season (for example, Spring).
Note: The season drop‑down list will only be displayed if seasonal limits have been configured. If a project is using temperature based device limits, this option will not be available.
• Voltage Limits: Specifies high and low voltage limits.
