Interval Pane
The Interval pane allows you to configure the forecast interval for the study. These options are only applicable to the Hourly Forecasts, Specific Day Forecasts, and Specific Period forecasts. Note that the maximum number of forecasts requested in a study is defined by the event management rule FLM Forecasts Study Period Defaults.
• Number of Hours: Set the number of hours over which the study will be run.
• Forecasts per Hour: Set the number of forecasts per hour. Note that if the FLM load period is set to 24 or less this option will be disabled and default to 1 forecast per hour.
