Context Menu Actions
The following context menu options are displayed when you right-click a row in the FLISR Report tool.
•	View...: Focuses the Viewer on the selected device.
•	SCADA Summary...: Displays the SCADA Summary window for the selected row in the SCADA Measurements table.
•	Flow Summary...: Opens the FLISR Flow Summary. This option is only available when a row is selected in the FLISR Solutions list.
•	View Isolate Switch...: Focuses the Viewer on the affected feeders for the selected isolate sequences. This option is only available for the selected row's isolation switch.
•	View Restore Switch...: Focuses the Viewer on the affected feeders for the selected restore sequences. This option is only available for the selected row's restoration switch.
•	View Limit Device...: Focuses the Viewer on the highest expected limiting device for the selected restore sequence.
