Menu and Toolbar Options
File Menu
Menu Option
Description
Toolbar Icon
Print...
Opens the Print Preview dialog box allowing you to print the Fault Location Analysis data.
Actions Menu
Menu Option
Description
Toolbar Icon
Isolate and Restore...
Opens the Suggested Switching wizard to generate a switching sheet with the Isolate and Restore option selected by default. See “Isolate and Restore Option for a Confirmed Fault” for information.
Display Fault Locations...
Displays the fault locations of the active event in the viewer. If there is more than one possible location, the viewer zooms out to show all locations, and Big Symbols is enabled.
Hide other Fault Locations...
Displays the fault locations of the active event in the viewer and hides the fault locations of all other events.
Hide Fault Locations...
Hides the fault locations for the event in the Viewer.
The Fault Location Analysis tab displays three sections:
• The SCADA Measurements section displays fault-related SCADA measurements used to identify probable fault locations.
• The FLA Messages section summarizes information associated with the fault location analysis. The information that could be presented include reasons for failure, status, and execution details such as solution start/end times.
• The Possible Fault Locations section displays the list of devices identified by the Fault Location Analysis tool as possible fault locations. If no valid fault locations are found, a single "Undetermined Fault" record is listed.
