Global | Feeder | Result |
Disabled | Disabled | FLA does not run |
Disabled | Sustained | FLA does not run |
Disabled | Momentary and Sustained | FLA does not run |
Sustained | Disabled | FLA does not run |
Sustained | Sustained | FLA runs and shows all DMS Statuses with (S) |
Sustained | Momentary and Sustained | FLA runs and shows all DMS Statuses with (S) |
Momentary and Sustained | Disabled | FLA does not run |
Momentary and Sustained | Sustained | FLA runs and shows all DMS Statuses with (S) |
Momentary and Sustained | Momentary and Sustained | FLA runs and shows initial DMS Status with (M) and final ones with (S) |
