Introduction
ANMS commands are steps in an ANMS switching sheet. Each ANMS switching sheet template allows you to create ANMS schemes using the ANMS Conditions tab to add ANMS trigger conditions.
When configured conditions are met by SCADA data, the system will create a new event in the Work Agenda and a new ANMS switching sheet will be created based on the template. The event refers to the activity, and the sheet contains steps and conditions copied from the template.
Execution of ANMS switching sheet steps can be done in Automatic or Manual modes.
