ANMS Template Specific Mode
The mode controls the processing and execution of the sheet based on the original template. The mode is sheet specific and can be in any of the following states.
• Disabled: No processing of scheme will happen.
• Manual: The scheme will be processed. When scheme conditions are met by the system, then an event will be created in the Work Agenda and an ANMS switching sheet will be created from the template. You must execute the sheet and complete the event.
• Automatic: The scheme will be processed automatically when scheme conditions are met by the system. An event will be created in the Work Agenda and an ANMS switching sheet will be created from the template. The steps in the sheet will be automatically executed.
Note: ANMS Template processing will happen only when a previously created sheet (if any) and event (if any) from this template are completed or canceled successfully.
Creating ANMS Switching Sheet Templates
ANMS Switching templates look like standard switching sheet templates with the addition of an ANMS Conditions tab that allows you to add conditions to an ANMS scheme and also set the scheme's ANMS mode.
