Selecting the Template's ANMS Mode
The ANMS Mode drop‑down list, available in the sheet template Request tab, allows you to select the operation mode for the scheme. The options are Disabled, Manual, and Automatic; the default value is Disabled. You may change the mode to Automatic or Manual after you have completed adding steps and conditions to the sheet.
The mode is included in the sheet title, which will be constructed as follows.
ANMS Template <Sheet ID> (<ANMS Sheet mode>)
