Understanding ANMS Events
The system processes ANMS schemes in regular cycles. When a scheme's conditions are met, the system will create an ANMS sheet from the template and create an ANMS event. The ANMS sheet's conditions cannot be deleted nor modified, but you may add, delete, and modify steps.
Note: The audit log shows the source ANMS template id from which it has been created.
Understanding ANMS Event Statuses
ANMS events refer to ANMS activities. Each event will be associated with an ANMS sheet. For these events, the status column in the Work Agenda shows one of the following values.
• A-NEW: New unacknowledged ANMS event.
• A-CMP: ANMS event has been completed.
• A-CNL: ANMS event has been canceled by the system.
