Option | Description | Toolbar Icon |
Export Table... | Opens a dialog box that allows you to save the current table view data to a comma separated value (csv) file. | |
Print… | Opens the Print dialog box, which allows you to print the currently selected report. | |
Exit | Closes the Topology Validation Viewer window. |
