Action Menu
The following table describes the
Action
menu options.
Option
Description
Toolbar Icon
Run Validation...
Opens the Run Validation dialog box, which allows you to choose the reports to run and select criteria for them.
View...
Focuses the Viewer on the selected device.
Refresh
Reloads all reports.
This site works best with JavaScript enabled
