Editing a User
To edit the name information for an Oracle Utilities Network Management System user, complete these steps:
1. Select the user you wish to edit in the Current Users table.
2. Click
Edit. The Add / Edit User Information dialog box appears.
3. Modify any of the enabled fields, as desired.
4. Click
Save. The user information is updated in the Current Users table.
Note: If the modified Username already exists, an error will appear and you will have to modify the username.
