Changing User Type Memberships
To modify the user type memberships for a user, complete the following steps:
1. Select the user whose memberships you wish to modify in the Current Users table. The User Type Memberships table populates with the current user type information.
2. Select the desired product from the Products column. The Remaining User Types and Current User Types columns populate with the user type information for that product for the selected user.
• To add a user type for a selected product, select user types from the Remaining User Types column.
• Click Add Selected User Types. The selected user type will move to the Current User Types column
• To remove a user type for a selected product:
• Select the user type from the Current User Types column. Click Remove Selected User Types. The selected user type will move to the Remaining User Types column.
Note: See the Oracle Utilities Network Management System Configuration Guide for details on adding and configuring user types.
