Resetting a User Login
To reset a user login, complete the following steps:
1. Select the user whose login you wish to reset in the Current Users table. The User Log table populates with the login history for the selected user.
2. Select the rows in the User Log table that pertains to the logins you wish to reset. The Reset Login button sensitizes.
Note: The Reset Login button is only available for rows where the Logout Date, Logout Status, and Logout Method columns are blank.
3. Click the Reset Login button. The User Log table updates the selected rows with the current date and time for the Logout Date, Forced for the Logout Status, and System for the Logout Method.
