Adding Permissions
You can add permissions for configured actions that are not in the Permissions table.
Note: You need to know the name of the configured action to be able to initiate the action. See the Oracle Utilities Network Management System Configuration Guide for details on configuring actions.
To add a permission do the following:
1. Click the Add... button.
2. In the Add/Edit Mobile Permissions dialog box, enter the following:
• Name: The name of the permission that you are adding.
• Description: A description of the permission.
• OMA: Drop‑down list allowing you to select whether the OMA user is allowed to perform the action (Yes) or not (No).
• FLEX: Drop‑down list allowing you to select whether the Flex Operations user is allowed to perform the action (Yes) or not (No).
3. Click Save Changes to save the new permission or click Cancel Edit to close the dialog box without saving.
