Using the Mobile Applications Tab
The Mobile Applications tab allows you to generate keys and administer keys that determine whether incoming messages are from an approved application. It also gives you a way of enabling and disabling an application while allowing other applications to continue to work.
See the Operations Mobile Application Installation and Deployment Guide for details.
