Friendly Name | Database Name | Database Description |
Set Name | set_name | A name used to identify what set a rule should belong to. |
Incident Type | incident_type | See each individual rule description for valid value for this column. |
Rule Name | rule_name | The name of the rule. |
Rule Value 1 | rule_value_1 | A character string. See each individual rule description for valid and default values, if applicable. |
Rule Value 2 | rule_value_2 | An integer value. See each individual rule description for valid and default values, if applicable. |
NCG CLS | ncg_cls | Used in conjunction with the ncg_idx value to narrow the application of a rule to a specific control zone. |
NCG Index | ncg_idx | Used in conjunction with the ncg_cls value to narrow the application of a rule to a specific control zone. |
Zone | N/A | The name of the control zone as derived from NCG CLS and NCG Index (as queried from the control_zones table). |
Rule Value Integer 1 | rule_value_integer_1 | An integer value. See each individual rule description for valid and default values. |
Rule Value Integer 2 | rule_value_integer_2 | An integer value. See each individual rule description for valid and default values. |
Rule Value Integer 3 | rule_value_integer_3 | An integer value. See each individual rule description for valid and default values. |
Rule Value Integer 4 | rule_value_integer_4 | An integer value. See each individual rule description for valid and default values. |
Rule Value Integer 5 | rule_value_integer_5 | An integer value. See each individual rule description for valid and default values, if applicable. |
Active | rule_active | The active state of the rule. |
