Add a Rule to the Configuration
To add a rule to the configuration, complete these steps:
1. Click Add to open the Event Management Rule Fields dialog box.
Note: If you had first selected a row in the Currently Configured Rules table, the dialog box will be initialized with the values from that row.
2. Select the name of the rule you wish to add from the Rule Name drop-down list.
3. Select the name of the rule set you wish to add the rule to from the Ruleset drop-down list.
4. Indicate whether or not you want the rule to be activated in the rule set by checking (or unchecking) the Active check box.
5. Enter the desired configuration values for the remainder of the fields.
Note: See the information in the Documentation pane for valid values for the fields.
6. Click Save to save the newly added rule.
7. If the newly added rule already exists in the specified rule set, a conformation dialog box appears.
• Clicking Yes overwrites the existing rule configuration with the new configuration.
• Clicking No will not add the new rule and you will be returned to the Event Management Rule Fields dialog box.
Note: This is the only validation currently performed when adding a rule. Please refer to the individual rule documentation in the Documentation pane for further information regarding valid values.
