Note: See the Documentation pane for valid field values.
4. Click Save. The rule information is updated in the Currently Configured Rules table.
Note: If you modify a rule's rule set to have values that already exists in that other rule set, an error dialog box appears. Clicking Yes will overwrite the existing rule configuration with the new configuration that you specified. Clicking No will preserve the existing rule.
For example, you select a Crew Incident Alarm rule that is in the Major Storm rule set and then select Minor Storm from the Ruleset options. If the rule already exists in the Minor Storm rule set, you will get the error.
This is the only validation currently performed when editing a rule. Please refer to the individual rule documentation for further information regarding what the valid values are for a particular rule.
