Reordering Options
To change the order of the options on an option menu, complete the following steps:
1. Select the Event Type whose option menu you wish to change.
2. Select the option menu you wish to change from the Event Details Option Menus drop-down list. The Options for Currently Selected Menu table populates with the options for the selected option menu and event type.
3. Select an option in the table that you wish to move in the list. The arrows to the right of the column are now sensitized.
4. Use the arrow buttons to rearrange options:
• Click the Move to top button () to move the selected user type up to the top of the list.
• Click the Move up button () to move the selected user type up one position in the list.
• Click the Move down button () to move the selected user type down one position in the list.
• Click the Move to bottom button () to move the selected user type to the bottom of the list.
