Editing an Option
To edit an existing option, complete the following steps:
1. Select the option package from the Schematica Option Package drop down under which the option you wish to edit comes under.
2. Select the category form Options Category whose option you wish to edit.
3. Select the option you wish to edit from the Options settings for selected option package table.
4. Click
Edit. The
Add/Edit Option dialog box appears. Make the desired changes.
5. Click
Save to save the new option. The Options settings for selected option package
table updates with the edited option.
