To generate and save SQL statements for the current state of the configuration associated with the Schematica Options tab, complete the following steps:
1. Select the Schematica Options tab.
2. Click Export Configuration.... A dialog box appears indicating that the configuration is being generated.
3. Once the generation is finished, the Generated Configuration dialog box appears.
• To save the generated SQL statements to a file, click Save. The Save Configuration File dialog box appears. Enter a name for the file in the File name field.
• To print the generated SQL statements, click Print. The Print Preview dialog box appears.
• Click the Cancel button to close the Generated Configuration dialog box
