The Refresh button refreshes the screen by reading the data from the database table. Any unsaved changes will be lost.
The Service Recache button causes the Oracle Utilities Network Management System services to recache with the changes you made in the Configuration Assistant window; otherwise, saved changes will not be recognized until Oracle Utilities Network Management System services are restarted.
The Save button saves any changes you have made.
Modifying a Feeder DMS Application Mode
1. Select a feeder or multi-select a set of feeders.
2. Select the application from the Actions menu and choose the mode; alternatively, you may right-click and select the mode from the application in the context menu. For example, with a row selected, right-click and select Forecasting from the FLM Status option.
Changing Feeder Color
To change the color of a feeder, right-click the feeder row and select Assign Color..., which will open the Choose a color for <feeder name> dialog box. You may select from existing NMS colors or from the available color libraries (that is, swatches, HSV, HSL, RGB, or CMYK). Click OK to update to the selected color or Cancel to close the dialog box without making changes. Click Reset if you wish to return to the original color.
