Using the Limit Configuration Tab
The Limit Configuration tab allows you to define limit groups and corresponding limit sets and limit bands. The measurements modeled in these limit groups trigger associated quality codes and alarms when values fall into non-normal bands.
Understanding the Limit Groups Table
The Limit Groups table has the following columns:
• The ID column displays the limit group number. This is a non‑editable field that corresponds to the measurement limit_group_id field and is here for reference purposes.
• The Group Name column displays the Limit Group name.
• The Description column displays the description given to the Limit Group.
