Buttons
• Add Limit Group...: Displays a dialog box that allows you to add a limit group.
• Edit Limit Group...: Displays a dialog box that allows you to edit the selected limit group.
• Remove Limit Group...: Removes the selected limit group.
• Refresh: Refreshes the entire tab.
• Service Recache: Notifies DDService to reload the new limit groups.
• Export Configuration...: Displays the SQL needed to create the data displayed in this tab.
Note: Limit group IDs need to be unique.
Understanding the Limit Sets Table
The Limit Sets table is displayed when a row is selected in the Limit Groups table. It has the following columns:
• The Set ID column displays the limit set ID.
• The Set Name column displays the limit set name.
• The Type column displays whether this limit set should use the value of the measurement, or a percentage. Percentages are only supported against the amp rating or nominal voltage.
• The Hysteresis column displays the value threshold past the limit needed to exit a non-normal limit band.
