Buttons
• Add Limit Set...: Displays a dialog box that allows you to add a limit set for the selected group.
• Edit Limit Set...: Displays a dialog box that allows you to edit the selected limit set.
• Remove Limit Set...: Removes the limit set from the selected group.
Note: A limit set ID can only exist once in a single limit group.
Understanding the Limit Bands Table
The Limit Bands table is displayed when a row is selected in the Limit Set table. It has the following columns:
• The Band ID column displays the limit band ID.
• The Band Name column displays the limit band name.
• The Min Value column displays the minimum value of this band.
• The Max Value column displays the maximum value of this band.
• The Description column displays the band description.
• The Priority column displays the priority used in the resulting alarm.
• The Enabled column displays whether the band is active.
