Using the Add / Edit Attributes Dialog Box
The Add / Edit Attributes dialog box allows you to create or edit existing attributes. The dialog box has the following fields:
• The Attribute column defines the name of the SCADA measurement.
• The Phase column defines the phase associated with the SCADA measurement.
• The Unganged column defines whether this measurement should be treated as ganged or un‑ganged by the alarm engine.
• The Tag column allows the alarm engine to group similar SCADA measurements together into parent and child alarms.
• The Product column is used to assign special meaning to a measurement. The following values are applicable:
• The Active column defines whether the attribute is active or not.
The following buttons are available:
• Save Changes: Saves the attribute and closed the dialog box.
• Cancel Edit: Cancels the action and closes the dialog box.
