Options Menu
Menu Option
Description
Set Wild Card Searching
• Before
• After
• Both
Options for setting a wild card searches: Before, After, or Both. Note that you do not have to add a wild card character (*).
Example: using the "After" wild card search.
returns:
• Mary S Abbott
• Mary Szbrinski
Use Sound Search
Returns searches with "sounds like" matches.
Example: Use Sound Search
returns:
• Fredric
• Fredrick
• Frederick
• Fred
• Freda
Use Exact Match Search
Returns only exact matches.
Set Max Searching Results
Opens the Set Maximum Searching Result dialog box where you can set the limit for matches to return.
The system will display a message when a search returns over 200 results, which is the maximum allowed by default.
Setting Debug
The Set Debug dialog box is initiated from the Help menu of all the NMS Environments. In some cases, issues cannot be properly diagnosed with only a list of actions the users partakes within the environment. In those cases, additional debug is required. The Set Debug dialog box should be used to turn debug categories on and off within an environment. When the dialog box is initiated from the Configuration Assistant user type, then additional options are available allowing the user to manage debug on all the clients and also within the Oracle Utilities Network Management System services.
