Once you have selected a customer from the search results, the customer account information is loaded into the Customer Weighted Priority Editor. The New Weighted Priority field, which is at the bottom of the Additional Customer Information pane, is the only editable field.
1. Enter an integer value in the New Weighted Priority field. Notice that the Save button becomes enabled.
Note: If you decide against editing the selected customer, click to reset the form.
