Resetting Weighted Priority
If you need to set a customer's weighted priority back to its original value, perform the following steps:
1. Search for the customer to load their data into the Customer Weighted Priority Editor.
2. From the Actions menu, select Reset to default. The New Weighted Priority field will be populated with the customer's original weighted priority value.
