Resetting the Model
Once all steps have been added to the Training Scenario sheet, select Reset Model... from the Training menu to return the to the nominal state. The system will present a dialog box asking you to confirm the action and warn of the actions taken in the Reset Model operation.
Reset Model Actions
• Completes all events; the other users do not get the opportunity to save any unsaved work.
• Closes all open sheets and safety documents for the trainer user except for templates and training scenarios; local changes to closed sheets are not saved.
• Changes all safety documents and sheets except for templates and training scenarios to the Training-Completed state.
• Cancels all pending momentary operations and expected actions.
• Closes all study sessions.
• Resets all delegated zones.
• Removes all tags and conditions.
• Resets all digital and analog measurements.
• Resets all commissioning/decommissioning to nominal.
• Resets all devices to their nominal state.
• Releases all crews.
• Cancels all active or incomplete events.
• Rolls back all model edits.
Click Yes to confirm that you want to reset the model. When the model has reset, the system will present the Reset Model Finished dialog box; click OK to close the dialog box.
