Playing a Training Scenario
Scenarios may be played from start to finish or to a selected step.
• When you wish to play the scenario to a certain point, do the following:
1. Select the row where you wish to complete and then pause.
2. Click the Play Scenario to Here () button. The NTS will present a dialog box asking if you wish to override the default offset to add time to each step.
• When you wish to play the entire scenario, do the following:
1. Click the Play Scenario () button. The NTS will present a dialog box asking if you wish to override the default offset to add time to each step.
In either play scenario, the steps will proceed and the synchronized training environment will change according to the steps.
