Using the Miscellaneous Log
The Miscellaneous Log records actions taken outside of a switching sheet. When you perform an action through the Operate Device dialog box (from the Map's Selection Panel), the Record Into Sheet field will show whether you are recording to the Miscellaneous Log or to a switching sheet.
See
“Using the Miscellaneous Log” for information on the Miscellaneous Log.
