Field Name | Nullable | Data Type | Description |
CONFIG_ITEM | N | VARCHAR2(32) | Column name in the TROUBLE_CALLBACKS database table, which should be populated from the PICKLIST_INFO_UPD_TR table. |
CONFIG_VALUE | N | VARCHAR2(32) | Column name in the PICKLIST_INFO_UPD_TR table, which should be used as the data source. |
