Parameter | Description |
config.enabled | Enable/disable. Default: true (enabled) |
config.strict_odin_format | Strictly adhere to the ODIN outage data format. Default: true |
config.publish.url | URL for publishing outage information. |
config.publish.format | Format for publishing outage information. Valid values: • xml - outage information is published as XML document • json - outage information is published in JSON format Default: xml in strict mode (required by ODIN), otherwise json. |
config.publish.period | Period for publishing outage information in minutes. Default: 15 minutes |
config.publish.timeout | Timeout in seconds for web service operations. Default: 30 seconds |
config.outage_id_format | Outage ID format. Format for generating outage identifiers for point outages. The '%d' string in the format is replaced with the NMS outage identifier (event index). When publishing to the Outage Data Initiative Nationwide (ODIN) website the specified format must make the outage ID globally unique. Default: %d |
config.include_spatial_info | Include spatial information with outage data. Implicitly disabled (set to ‘none’) if config.strict_odin_format is set to 'true'. Valid values: • outage - include for point outages • area - include for area outages • all - include for point and area outages • none - do not include spatial information Default: none |
config.utility_id | Utility ID. Preferably, it is the unique identifier used by the Energy Information Administration for reporting. |
config.utility_id_authority | Name of the authority responsible for managing utility ID (Utility, EIA, NERC, and so forth). |
config.utility_name | Utility name. Preferably, it is the unique identifier used by the Energy Information Administration for reporting. |
config.utility_name_authority | Name of the authority responsible for managing the utility name (Utility, EIA, NERC, and so forth). |
config.auth.url | URL of OAuth server. If provided then the credentials specified by the config.auth.user and config.auth.pwd parameters will be used when contacting the OAuth server and the obtained token is then used when publishing outage information. If not provided, then the configured credentials are used directly when publishing outage information using the basic HTTP authentication mechanism. |
config.auth.scope | The scope value used when requesting OAuth token. |
config.auth.user | Username/client id. |
config.auth.pwd | Password/client secret. This parameter should be stored in encrypted form. |
config.area_type.zipcode | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘zipcode’ area type. |
config.area_type.county | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘county’ area type. |
config.area_type.state | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘state’ area type. |
config.area_type.township | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘township’ area type. |
config.area_type.ward | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘ward’ area type. |
config.area_type.parish | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘parish’ area type. |
config.area_type.borough | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘borough’ area type. |
config.area_type.serviceArea | Value of the GEOGRAPHIC_OUTAGE_AREAS.AREA_TYPE column for the ‘serviceArea’ area type. |
