Client Development Installation Overview
Follow these steps to install, build and deploy the Oracle Network Management System Operations Mobile Application:
1. Use the table in the Hardware Requirements section to identify the supported build environment platforms.
2. Review and prepare for the download and installation of required Oracle and third-party software as described in the section Prerequisite Software.
3. Install the third-party software.
4. Unzip the Oracle Network Management System Operations Mobile Application project files from the $NMS_BASE/sdk/OMA2.zip file to your build environment system.
5. Unzip the Oracle Network Management System Operations Mobile Application 3rd party files from the $NMS_BASE/sdk/OMA2.3rdparty.zip file to your build environment system.
6. Install the Node.JS from https://nodejs.org. You will need version 14.17.3 or higher.
7. Build the Oracle Network Management Systems Operations Mobile App.
8. Run the built client using the browser to test your built application.
