Client PWA Installation Instructions
OMA is a PWA application and can be installed on the following types of systems.
Platform
Supported Browsers
Windows 10 and above
Google Chrome
Microsoft Edge
Linux
Google Chrome
Android Tablets or Phones
Google Chrome
iOS Tablets or Phones
Safari
OMA installation is done by using the devices browser and connecting to the OMA application website.
OMA has a standardized installation process for Android, iOS, Linux, and Windows:
1. Launch the browser to the https server where OMA is installed. (for example, https://host.com:8889/mobile/oma2/www/index.html).
2. On launch, the browser will detect the app is a PWA and will start the download of the PWA to the browser cache storage. This will be identifiable to the user by the flashing "Downloading Update..." in the OMA header bar:
OMA log in page with "Downloading Update..." message.
3. On iOS, while the PWA is downloading, a dialog screen will be displayed with instructions for installing OMA after the download is complete.
4. Once the PWA download is complete, on all but iOS devices, an Install as PWA button will replace the flashing Downloading Update... notification.
5. Click the Install as PWA button.
6. On iOS systems, once the Downloading Update... is complete, navigate to and press the Share... button (iOS Share icon.). Select the option to add OMA to your home screen. Press the OMA icon on the home screen to start the PWA.
7. On Windows with Chrome:
a. You will be presented with an installation dialog box. Click the Install button to install it on the device.
b. The PWA will close in the browser tab and open as a standalone PWA app.
c. The PWA will be given a start menu option from where you can launch the app, pin it to the taskbar, pin it to the start menu, or open the location of the app and copy it to the desktop.
8. On Windows with Microsoft Edge:
c. You will also be provided a dialog about installation options:
App installed notification dialog box.
9. On Android Chrome:
a. You will be presented with an installation dialog. Click the Install button to install it on the device.
b. A small temporary message will indicate the app is being added to the home screen.
c. Close the browser and the home screen should be focused on the location of the OMA app icon. Feel free to drag it to any location on the home screen(s).
d. To launch OMA as a PWA, just click on the OMA launch icon.
10. On Linux Chrome:
c. The PWA will be given a start menu option, most of the time under section identified as Chrome Apps. From there you most likely will be able to drag it to the desktop.
d. To launch OMA as a PWA, click the OMA launch icon.
