Menus and Toolbar Buttons
File Menu
Menu Option
Description
Toolbar Icon
Refresh
Refreshes the data in the Trend Graph window with the selected control zone's data.
Print...
Prints the trend graph for the selected region.
Pin
Click to pin the graph, which will open new graphs in separate windows. If a graph is not pinned, then when the Trend Graph option is selected again, the current window will display the data for the new selection.
Note: You may pin multiple graphs.
Exit
Closes the Trend Graph window.
Help Menu
Menu Option
Description
Toolbar Icon
Graph Tool Help...
Opens the online help system to the Trend Graph help content.
The graph will show the predicted values and the actual measurements over the given period of time. If a measurement is done for an attribute that has multiple phases, all of the phases will be shown on the graph.
The start and end dates can be changed by selecting a date and time in the Begin Date and End Date fields.
Lines can be hidden by deselecting the symbol in the legend:
Screen capture of line symbols selected and deselected.
If you hover the mouse over a point on the graph, the details of the measurement will be shown.
