Status Bar
The status bar displays at the bottom of the Feeder Load Management window. Screen capture of the status bar with annotations corresponding to 1) the mode indicator, 2) data update notifications, and 3) the Refresh button, which allows you to update the data manually.
It provides the following information and functions:
1. Real-time or study mode indicators.
2. Indicates if data has been updated.
3. Refresh button ().
