Menu Option | Description | Toolbar Icon |
Print... | Opens the Print Preview dialog box allowing you to print the Fault Location Analysis data. |
Isolate and Restore... | Opens the Suggested Switching wizard to generate a switching sheet with the Isolate and Restore option selected by default. See “Isolate and Restore Option for a Confirmed Fault” for information. | |
Display Fault Locations... | Displays the fault locations of the active event in the viewer. If there is more than one possible location, the viewer zooms out to show all locations, and Big Symbols is enabled. | |
Hide other Fault Locations... | Displays the fault locations of the active event in the viewer and hides the fault locations of all other events. | |
Hide Fault Locations... | Hides the fault locations for the event in the Viewer. |
